STEM
STEM
Soil-moisture modeling
    • Rajesh Nandi
      I want to model soil-moisture retention using FLUENT. I will apply different layer of materials (bio-fertilizer) on top surface of soil and see how much moisture in the soil is retained after a certain period of time. I am new in ANSYS and don't know if it's possible to solve this in FLUENT. I have the code (MATLAB) to solve the problem. How can I import the code in FlUENT? Do I have to use other suite?
    • Vivek Praveen
      Hi Rajesh,
      ANSYS FLUENT has the capability to simulate fluid flow and heat transfer in porous media, and can be used to model soil-moisture retention. You can set up the soil as a porous media and apply appropriate boundary conditions to represent the application of bio-fertilizer, and simulate the flow of water over time to determine the moisture content at different depths.
