Solder Joint Fatigue Life Prediction V2.5
    • nellysh2017
      Hello,nI want to use Solder joint fatigue life prediction ACT with ANSYS 2020R1. however when I click on the solder icon, nothing happens, can someone please explain what is the problem?n
    • Aniket
      Extensions typically are bit behind for updates, as these are available for free. Our development team is actively working on making these extensions available in latest realease.nBut as of now, if you have access to Ansys versions R19.2, you should be able to run this extension, as the extensions are version specific.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
