March 16, 2021 at 3:00 pm
HuiKhi7
SubscriberMarch 16, 2021 at 8:57 pmpeteroznewman
SubscriberHi Skye nIt looks like you have the SAC305 meshed.nAll the other components should have solid geometry that touches this body on coincident faces. If you bring all those solids into SpaceClaim, use the Share button on the Workbench tab to create and verify Shared Topology. Then when you mesh it, you should get congruent meshes and not need any contact.nRegards,nPeternViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2142
1355
1144
462
