Solid bodies
    • ARSH SIDHU
      How we connect solid bodies into one part one body in ansys.
    • Jurjen
      Dear ARSH SIDHU,
      You can merge solid bodies by opening your geometry in the DesignModeller.
      Than creating a boolean and unite/merge bodies by updating.
      I hope this helps!
    • peteroznewman
      Your question has many answers depending on the specific case.
      Here are a list of methods of connecting solid bodies into one part, one body or the equivalent in a model.
      • Unite the solid bodies in DesignModeler or SpaceClaim into one body
      • Put the solid bodies in a single component in SpaceClaim and set Shared Topology to Share or Form New Part in DesignModeler
      • Mesh the bodies with congruent nodes on the shared faces and use Node Merge to make a single meshed body
      • Add bonded contact to the bodies and they will behave like one body
      • Add a fixed joint between the bodies and they will behave like one body
      If you reply with a specific example, I can recommend a specific method.
    • ARSH SIDHU
      Thankyou, its done.
Viewing 3 reply threads
