January 5, 2023 at 7:57 pm
Chowdhury Sakib-Uz-Zaman
Subscriber -
January 6, 2023 at 5:10 am
Nikhil Narale
Ansys EmployeeHello,
Try following these steps:
Go to 'Create' > 'Body Operations' > Set 'create solids' and merge bodies' (optional) to 'yes' > Select all the surfaces and execute the task.
Otherwise, I would recommend you to use Repair > 'Stitch' option in Ansys Discovery/SpaceClaim.
Thanks!
Nikhil
January 9, 2023 at 5:50 am
SubscriberThank you so much!!! The first method has exactly solved my problem!!
January 6, 2023 at 9:59 am
Ansys EmployeeTry STEP and Parasolid too. The gold tick on the import implies something didn't quite work, so try another format (IGES isn't always a good option).
January 9, 2023 at 5:52 am
SubscriberThank you so much for your reply!!!
2524
2066
1279
1096
457
