Discovery Import
Discovery Import
Solid is not rigid
    • t4
      Hi
      I ran a simulation of a tweezers with load on each part of the handle. The solid deformed and self intersect like in the attachment. Please advise how to overcome this issues. The solid should self collide and deformed again. Am I missing some setting?
      Thank you.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Naresh Patre
      Hello Rapid Team
      This is a problem of non linear contacts which cannot be modeled in Discovery Live as of now. However, you should be able to do this using Discovery AIM. Please check out tutorial 4 from below link which involves non-linear contacts.
      https://discoveryforum.ansys.com/t/x15k18
