March 28, 2021 at 8:23 pm
LB38
SubscriberI am using this student software for the first time, I tried to import a solid model in forms: .STL, . IGES, etc. The screen automatically opens up SpaceClaim and the model is visible in SpaceClaim, when I try to export the model in workbench I know I have to use .ANF (Ansys Neutral File). But for some reason I do not have this option. When I go back to workbench, Geometry under Static Structural has two lower case letters sc and the model is also not visible in workbench. What am I supposed to do in order to get the model in workbench in order to analyze it? I see no DSP connection as well and I don't know if I need to fix my licenses and what do I do to fix it. n -
March 29, 2021 at 10:21 am
Ansys EmployeeAs you can open files it sounds like the software is working. If you click on Help in Workbench navigate up to the list of software and find the solver of interest. The tutorials will guide you through the whole process.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2706
2142
1355
1144
462
