June 7, 2020 at 5:05 pm
reza1374
Subscriberthe better value for restitution coefficient for solid-wall in hydrodynamic gas-solid bubbling fluidized bed?can i assming near one (elastic) for better result example 0.9 or 0.95 or 0.99?or near zero? in the article not mentioned.
if not mentioned in article, can i assume granular flux is zero?
June 8, 2020 at 5:30 am
DrAmine
Ansys EmployeeIf nothing is mentioned I would keep it as default so elastic. Generally it will be a function of the impact angle which depends on the surface at impact and particle surface properties. In general tangential coefficient is lower at higher angle but remains higher than normal.
3812
2605
1849
1244
600
