SOLID186 – Layered Structural Solid Element
    • olivier laplanche
    • Ashish Kumar
      Forum Moderator
      Hi Olivier,
      Can you please share the details of your query?
      Ashish Kumar
    • olivier laplanche
      context is conversion from ANSYS to Dyna (based on a .cdb file).
      what is the meaning of each field of below solid element card :
      EBLOCK,19,SOLID,   1
      (19i9)
              6      186        0        1       11        0        0        0       20        0       65       82       83       84       85       86       87       88       89
             90       91       92       93       94       95       96       97       98       99      100      101
      and associated layered sequence :
      SECTYPE,53191,SHELL
      SECOFFSET,USER,0
      SECBLOCK,9
      0.0500909417,4,0,3
      0.200000254,6,43.7648948,3
      0.200000254,6,-173.454251,3
      0.200000254,6,41.3467438,3
      0.200000584,4,0,3
      0.0249337477,4,0,3
      thanks
    • mjmiddle
      Please see the Ansys documentation page:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/ans_prog/Hlp_P_INT3_3.html%23dLN4r34clcd
    • olivier laplanche
      Thanks for feedback and in addition :
      considering that, in my case, the material is defined by layers, has the material defined in the element any purpose ?
    • mjmiddle
      The materials set for each layer will override what is set on the solid186 element.
Viewing 5 reply threads
