October 1, 2023 at 6:00 pm
harshit gupta
SubscriberWhat is the role of thermal expansion coefficient in solidification simulation in ansys fluent? and what should be the value of thermal expansion coefficient for solidification of water. This data we need to fill in the material properties I am wondering that this property was not asked in the old fluent version but asked to fill in 2022R2.
October 3, 2023 at 12:54 pm
Forum ModeratorDid you turn on the buoyancy option? That looks to be new and should be covered in the documentation.
October 4, 2023 at 9:27 am
harshit gupta
SubscriberI am using the Boussinsq approximation for the density in the material properties window for the buoyancy.
Is there any other option to turn on/off buoyancy?
Please tell me and thanks for the reply
October 4, 2023 at 11:08 am
harshit gupta
SubscriberI had considered the gravity also as -9.81m/s2
October 4, 2023 at 11:23 am
Forum ModeratorOK, with Bousinesq there's an expansion coefficient. There's also a setting in the solidification panel in 23R2.
October 7, 2023 at 2:42 pm
harshit gupta
SubscriberHow to model the change in the volume of the ice (when it solidifies from water) due to the change of temperature/density, in the ansys fluent
October 9, 2023 at 8:41 am
Forum ModeratorYou'll need to add in a temperature dependent density, but with water being rather strange you may nee expressions or a UDF. Note, the ice won't float: read how the model works.
8700
4658
3151
1672
1448
