November 15, 2018 at 7:02 pm
JuanIvorra
SubscriberI am trying to put the Ansys 19.2 (student edition) the Add-in in Solidworks student version.
I run as an administrator the cad configuration manager and I am getting this:
Prerequisites ..... Configure Success
SW Workbench PlugIn ..... Not Configured
CAD Configuration log file was written to location: C:Program FilesANSYS IncANSYS Studentv192CADConfigLogsLatestCADConfigurationMgr.log
November 15, 2018 at 7:39 pm
tsiriaks
Ansys EmployeeHi JuanIvorra,
Please see the discussion in here
https://forum.ansys.com/forums/topic/nx11-to-ansys-17-1-trouble/
Student version doesn't support any 'plugin'
Thank you,
Win
November 16, 2018 at 8:08 am
Keyur Kanade
Ansys EmployeePlease use reader mode only as plugin mode is not supported.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
459
