March 10, 2021 at 1:19 pm
hamuza
Subscriberi read many posts on the community that students don't have access to customer portal but they can use ansys workbench help no I am need help with my ic engine geometries how ill I proceedn -
March 10, 2021 at 1:58 pm
1shan
Ansys Employee,nPlease check https://forum.ansys.com/discussion/3978/how-to-access-the-ansys-online-help on how to use the help documentation with the student version. You could also post specific questions regarding your problem on the forum, with supporting images describing the issue.nRegards,nIshan. n
Trending discussions
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
