February 4, 2021 at 7:51 pm
chrumdzik
SubscriberHello,
I can not add user defined solutions due to disable of worksheet.
How can I find this list from second snapshot ?
Thanks in advance
February 8, 2021 at 4:38 pmAniket
Ansys EmployeeYou need to solve the analysis first and then click on the solution branch of the tree to enable the worksheet.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5368
3363
2471
1310
1020
