August 31, 2019 at 3:52 pm
Twain
SubscriberHello there,
In order to check my simulation, i added animations via, GUI:
Solution / activities / create + / solution animation
This works without a problem, animations are generated every 200 Iteration.
(pictures saved within autosave)
In order to speed up the simulation, I am using a fluent v194 Linux cluster.
Using the same case-file and UDF as used on my computer (via journal):
Ansys does not generate these animations at all..... .
What do i have to do in order to get these animations working?
Thanks in advance.
Twain! -
September 2, 2019 at 10:50 am
Ansys EmployeeDid you launch Fluent via batch script? Does the cluster have a graphics card?
September 3, 2019 at 5:26 am
DrAmine
Ansys EmployeeHow are you starting? You require graphics flag in batch.
2620
2098
1323
1110
461
