November 12, 2018 at 11:08 am
Ananth Narayan
SubscriberHello everybody,
May I know the meaning for the statement " Solution has converged". What this implies about the solution.
Regards
November 12, 2018 at 11:19 am
seeta gunti
Ansys EmployeeHello,
Solution has converged tells you that your simulation has reached to unique solution and it is ready for post-processing. This statement generally comes once the case residuals reaches to the limits ( set by you). By default, Fluent sets to 1e-03.
Many cases, if the residuals are reached to 1e-03, solution would converge but for better converging the case, it is suggested to check the mass balance, energy balance also. Apart from this, you can set the monitors and check the converge for the monitors as well.
Seeta
November 12, 2018 at 12:35 pm
Ananth Narayan
SubscriberFirst what is residual?. Are there any tutorial to set monitors to check converge.
November 12, 2018 at 12:40 pm
Keyur Kanade
Ansys EmployeeResiduals are local imbalance of variable over control volume. This arises from the CFD methods applied.
Request you to go through basics of CFD to understand the numerical methods. Also please check help manual on convergence.
November 12, 2018 at 12:53 pm
Ananth Narayan
SubscriberCan you suggest books or tutorial for all basic terms related to ANSYS CFD
November 12, 2018 at 1:07 pm
Keyur Kanade
Ansys EmployeePlease check following section on forum.
https://studentcommunity.ansys.com/cat/support-resources-tutorials/
2564
2080
1299
1106
459
