Solution Data export doesn’t match simulation
    • psayasith
      I attached two pictures, one of the exported data and one of the coutour plot from which the data was exported.  The exported data's pressure column was completely different from what it should have been.  It hovers at around 760 torr, while the other sits around 6.  I've confirmed that the same unit of pressure is used in both.  Is there a reason why my pressure is completely incorrect in the export, is it being scaled or relative to something that I am not aware of?
      Thank you,
      Peyton
      Can you double check the export? 760 Pa is about 6 Torr. Fluent works in SI units, and will work with SI in the background regardless of the setting in "Units".
