Solution Error
    • darshan
      I am doing Analysis of heat dissipation of taper roller bearing using FEA at a 2050 RPM for time of  20 hours. but i don't know how to do it in ANSYS ,. i tried many times but it solved partially and showing error. this is my research ares of my study. please help in this problem.. it will be very helpful for me please.
      please find attachment  for bearing design
      thank you.
    • peteroznewman
      I see the bearing geometry. The heat dissipation will be largely determined by the flow of heat into the housing and along the shaft. Tapered roller bearings must be used as a pair. Where is the other bearing?  What kind of lubrication is being used?
      I suggest you attach an ANSYS archive file so I can see the surrounding geometry and the error.
    • darshan
      ok sir. i will attach
    • peteroznewman
Viewing 3 reply threads
