January 18, 2018 at 6:24 am
karthikyogi01
Subscriberanybody can give the solution for calculating the wear rate in ansys cfd and also the how to simulate the wear rate and electrolysis.
January 20, 2018 at 4:06 pm
SubscriberFrom your other post, you wrote,
am doing the project based on wear analysis..
so please help me to solve the wear rate with temperature distribution in ansys fluent..
I assume there is an abrasive fluid that is causing the wear due to the flow over time. Please describe in detail the fluid/solid properties as well as the concentration of solid particles in the fluid.
Please use the Attach button that is available on you post above to attach an ANSYS Project Archive (.wbpz file) that shows the geometry, inlets, outlets, walls and themal boundary conditions.
Here is a relevant document on how to simulate erosion using ANSYS CFD. Did you already find this?
January 21, 2018 at 6:33 pm
Raef.Kobeissi
Subscriber -
January 22, 2018 at 6:17 pm
karthikyogi01
Subscriberthank you sir both..
and can you give your personal mail id for me to discuss with some problem in heat transfer analysis in cfd fluent.
my mail id is "karthikyogi01@gmail.com"
2656
2120
1345
1118
461
