Solution Interpolation for LES
    • krany3
      I'm trying to use the RANS solution as an input for LES. I did mesh adaption. Do I have to interpolate the RANS solution on to the LES mesh? Can I directly run LES without interpolating?
    • DrAmine
      You can read the interpolation file and then make outside of the velocity field some instantaneous quantities ((before turning to LES). Check LES-Specific Solution Strategies in the documentation.
    • DrAmine
      You can read the interpolation file and then make outisde of the velocity field some instantaneous quantities (solve/initialiaze
