Solution Method – Flux Type
    • SilverRD
    • Nikhil Narale
      1: With the 'Flux Type' user can select the method to calculate Mass Flux while solving. The methods you see here will change if you select Density based solver.
      2: For compressible fluids, it is recommended to select 'Rhie-Chow: distance based' method.
      For more details on the Flux method, please refer to there two links:
      1: For pressure based solver: 32.3.2. Mass Flux Types (ansys.com)
      2: For density based solver: 32.4.2. Convective Flux Types (ansys.com)
      If you are facing issue while accessing the above links, please refer to this forum discussion: Using Help with links ÔÇö Ansys Learning Forum
      Nikhil
    • SilverRD
      Thank you I really appreciate your help...
    • Nikhil Narale
      You are welcome!
      Nikhil
      • lancer
        Is this available in ANSYS 2021 R1 because I couldn't find it?
Viewing 3 reply threads
