Solution name in Python
    • johnstn
      Hi. Is it possible to get the solution name and use it as variable on Python?
      I'd like to get this "Static Structural (A5)" and use it in a code to export the data.
      I have a lot of containers and if I keep this "DATEI_NAME", it will write the exported data in the same xls of the previous solution.
      Thank you
    • Erik Kostson
      The way to get that name (but (A.. is not part of it is):
      ExtAPI.DataModel.Project.Model.Analyses[0].Name
      There is also the internalobject, which is to be used with care (might not always work):
      ExtAPI.DataModel.Project.Model.Analyses[0].InternalObject.DisplayName
      This gives also the (A..) part
      Erik
    • johnstn
      Hi Erik
      Thank you for your answer. It works. However, I get the "(A...)" in the name.
      Is it possible to get the name of the current analysis (based on the selected results)?
      I would like to run a script for each container, not changing the [0] in the code. The script should read each result selected in "Solution" and export to an xls file.
      Thanks again
    • johnstn
      I found out how to do it...
      I added this code to find out the "i" in Analyses[i] and remove the "(A....)" from the string.
      numberAnalysis=Tree.GetPathToFirstActiveObject()
      nameAnalysis=numberAnalysis[numberAnalysis.find('[')+1:numberAnalysis.find(']')]
      nameExport=ExtAPI.DataModel.Project.Model.Analyses[int(nameAnalysis)].InternalObject.DisplayName
      nameExport=nameExport[0:nameExport.find('(')-1]
      Thanks 😀
Viewing 3 reply threads
