Solution not converged (Symmetric RC Beam)
    • Daniel97Yii
      I'm modelling a half RC beam, as shown.
      This is the material command for concrete:
      et,matid,solid65
      MP,Ex,matid,24000
      MP,Prxy,matid,0.2
      MP,Dens,matid,2320e-9
      TB,concr,matid
      tbdata,1,0.3,1,0.304,25
      This is the material command for reinforcement:
      ET,MATID,LINK180
      MPDATA,EX,MATID,2e5
      MPDATA,PRXY,MATID,,0.3
      TB,BISO,MATID,1,2
      TBDATA,,500,2100
      R,MATID,6,,0
      Mesh settings:
      1. For concrete, Patch conforming method, tetrahedrons, element midside nodes dropped.
      2. For reinforcements, Body sizing, 1mm, soft behaviour.
      Symmetry: Symmetric region applied at the face of the middle of the beam.
      Analysis settings:
      1. Solver controls
      Solver type, weak springs- program controlled, large deflection & intertia relief- off.
      2. Non-linear controls
      Force & displacement convergence- on. The rest under non-linear controls are program controlled.
      Preprocessor command:
      /PREP7
      ESEL,S,ENAME,,65
      ESEL,A,ENAME,,180
      ALLSEL,BELOW,ELEM
      CEINTF,0.001
      ALLSEL,ALL
      /SOLU
      OUTRES,ALL,ALL
      Displacement applied on the edge of "add frozen" concrete body. Free only at x-direction, constant at y & z direction.
      Solver Output:
      *** ERROR ***                           CP =      18.422   TIME= 21:23:01
       Solution not converged at time 1 (load step 1 substep 1).
        Run terminated.
       *** WARNING ***                         CP =      18.422   TIME= 21:23:01
       The unconverged solution (identified as time 1 substep 999999) is
       output for analysis debug purposes.  Results should not be used for
       any other purpose.
               R E S T A R T   I N F O R M A T I O N
       REASON FOR TERMINATION. . . . . . . . . .UNCONVERGED SOLUTION
       RESTART BY RE-RUNNING THE ANALYSIS
      Above are the details of the model settings, which doesn't yield proper result. Please guide me through my problems. I'm not sure how to rectify the error.
      Below are the deformation response under this setting:
      View in 1.0 (True scale) (above image)
      View in 5x (Auto)
    • peteroznewman
      In Workbench, under Analysis Settings, turn on Auto Time Stepping.
      Set the Initial and Minimum Substeps to 100 and the Maximum Substeps to 200.
    • Daniel97Yii
      Below are the results after adopting your suggestion.
      One error appears.
      How to rectify the error?
    • peteroznewman
      You have to set the Mesh Element Order to Linear if you want to use 8 node hex elements and you have to set the Element Order to Quadratic if you want to use 20 node hex elements.  You have left it Program Controlled and it meshed with an element order that does not match the SOLID65 element type.  Furthermore, if the element type is only a Hex element, you can't allow the mesh to have any Tetrehedral shapes (and vice versa).
      SOLID65 is an obsolete element. I can't even find it in the 2019 R3 help system.  Consider changing to a current technology element.
    • Daniel97Yii
      I'm using ANSYS R14.5.
      Solid65 can be found in Element reference>Element classification>Summary of element type in ANSYS Help?
    • peteroznewman
      SOLID65 is a Linear element so set the Mesh to use Linear elements.
    • Daniel97Yii
      Mesh settings:
      If I have not mistaken, element midside nodes dropped= linear?
Viewing 6 reply threads
