September 24, 2018 at 8:45 pm
mekafime
Subscriber -
September 24, 2018 at 9:14 pm
SubscriberLook at your Newton-Raphson Force Residual plots to see where the solver is having trouble converging. Make smaller/better shaped elements near the area of maximum N-R Force Residual.
September 24, 2018 at 9:43 pm
Sandeep Medikonda
Ansys EmployeeYes, also please see these suggestions from the help section:
When Advanced Contact is NOT Present in the Model ...
Check for sufficient supports to prevent rigid body motion (structural) or check for thermal material curves or convection curves which rise and/or fall sharply over the temperature range (thermal).
If you encounter a convergence error during a thermal analysis that is using contact, consider modifying the Thermal Conductance property.
When Advanced Contact IS Present in the Model ...
Check for sufficient supports to prevent rigid body motion or that contact with other parts will prevent rigid motion.
Check that the loading is of a reasonable nature. Unlike linear problems whose results will scale linearly with the loading, advanced contact is nonlinear and convergence problems may arise if the loading is too big or small in a real world setting.
If the contact type is frictionless, try setting the type to rough. This may help some problems to converge if any possible sliding is not constrained.
Check that the mesh is sufficiently fine on faces that may be in contact. Too coarse a mesh may cause inaccurate answers and convergence difficulties.
Consider softening the normal contact stiffness KN to a value of .1. The default value is 1 and may be changed by setting the Normal Stiffness. Smaller KN multipliers will allow more contact penetration which may cause inaccuracies but may allow problems to converge that would not otherwise.
If symmetric contact is being used (by default the contact is symmetric), consider using asymmetric contact pairs. This may help problems that experience oscillating convergence patterns due to contact chattering. The program can be directed to automatically use asymmetric contact in the Details view of the Contact Folder.
Sandeep
September 25, 2018 at 3:22 am
September 25, 2018 at 3:44 am
Sandeep Medikonda
Ansys EmployeeCan you explain, what kind of analysis you are performing and provide details/snapshots of any contacts, analysis settings etc?
Sandeep
September 25, 2018 at 3:47 am
mekafime
SubscriberAttached
September 25, 2018 at 4:16 am
Sandeep Medikonda
Ansys EmployeeI am unable to look at the file, maybe someone else on the community can take a look at it.
Sandeep
September 25, 2018 at 2:15 pm
September 25, 2018 at 3:10 pm
Sandeep Medikonda
Ansys EmployeeI vaguely remember seeing this model before. Did Peter help you with this before?
Coming to your model, can you show the details/snapshots of the contact and the material you are using? Also, what mesh do you have? Can you try a run dropping the mid-size nodes?
Sandeep
September 25, 2018 at 3:25 pm
September 25, 2018 at 5:54 pm
Sandeep Medikonda
Ansys EmployeeJust change Element Order under Details of "Mesh" to Linear and run a case?
Also, I was referring to the Details of the Contacts?
September 25, 2018 at 8:45 pm
September 27, 2018 at 12:27 pm
September 27, 2018 at 2:14 pm
September 27, 2018 at 3:16 pm
2080
1315
1108
459
