Solution XY Plot
    • designteam2
      How do you plot the results of a simulation on a cylinder using a mid plane? This is in regard to the XY plot function in the solution tab.
      Thank you!
    • Keyur Kanade
      you will need to define some line for plot.
      please check following.
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • raul.raghav
      Since you've tagged CFD-Post, refer to the attached video:
