April 6, 2022 at 7:52 pm
jnelsen33
SubscriberI am doing a simulation of hurricane force winds on a home. I have adjusted my range to only show pressure values that we've determined will likely cause damage....because I adjusted the range, there are large portions of the home without anything shown other than the mesh. Is it possible to solve only the area of the contour/home that are in the range that I've specified, while ignoring the blank spaces?
Thank you.
April 7, 2022 at 5:09 amKeyur Kanade
You can click off Draw mesh option in contour display panel.
Please check help at following link for more information.
48.2.15. Contours Dialog Box (ansys.com)
Regards Keyur
April 7, 2022 at 5:33 amjnelsen33
SubscriberAnd where exactly does it show the area of the contour? I'm pretty sure clicking off Draw Mesh just removes the surface that the contour is shown on. I need a numerical value for the area that the adjusted range of the contour is covering.
April 7, 2022 at 10:45 amRob
Ansys EmployeeIf you want the area of a contour for a certain value (or more specifically range of values) use an iso-clip on the surface of interest rather than a contour.
2726
2156
1359
1150
462
