September 10, 2019 at 6:41 am
danieleobiso
SubscriberHello everyone,
I am trying to have an export during the solution of a Tecplot file or ANSYS Mechanical (get the same error for both cases). The export works if I do it manually.
If I enable an export "During solution" I observe a weird behavior.
1) Everything works under Windows (which is not my solution, because I have to run on a Linux cluster)
2) Under Linux, the files are exported but the software crashes before starting the next time step with this error:
Error: malformed pair: too many objects in CDR
Error Object: (continuity . 0)
Now, I have tested it on different Fluent versions (17.2, 19, 19.2, 19.4), different Linux OS (OpenSuse, RedHat Enterprise) and I always get the same error. I sent the case to ANSYS Customer Support and they cannot reproduce the error.
Is there someone aware of this behavior? Have you encountered it before?
Thanks in advance,
Daniele
September 10, 2019 at 10:16 am
Ansys EmployeeIf it works on Windows & on the ANSYS system check the RAM & disc space & access permissions on your cluster: I assume the LINUX builds are on the supported list?
September 10, 2019 at 10:22 am
DrAmine
Ansys EmployeeDear Mr. Obiso, I asked my colleagues from developments if they have any idea about this. I will share any information within the supprot request.
September 10, 2019 at 10:40 am
danieleobiso
SubscriberRed Hat Enterprise is supported
September 10, 2019 at 12:18 pm
DrAmine
Ansys EmployeeWe are helping on a resolution of this problem.
September 10, 2019 at 2:21 pm
DrAmine
Ansys EmployeeSolution was here to set LC_NUMERIC (in other cases the LANG) to en_US. This variable determines the locale category for numeric formatting.
Many thanks for testing and checking.
September 10, 2019 at 3:30 pm
danieleobiso
SubscriberThank you Amine for your solution.
The problem was indeed the environment variable LC_NUMERIC not set to en_US.
By the way, I tested the automatic updating of the iso-surface and it is working! The previous behavior was probably depending on that other issue.
September 10, 2019 at 3:41 pm
DrAmine
Ansys EmployeeThanks for the update. Happy that you can now continue Working.
Just mark this as Is Solved so tgat other members can get advantage of the content of this discussion.
2630
2110
1335
1110
461
