3D Design
3D Design
[Solved] Unable to attach geometry file on ANSYS Student Fluent
    • 19182560
      Geometry won't attach to the mesher and I'm not sure why. For what it's worth, I'm using ANSYS on mac using Parallel as my VM.
    • 19182560
      Figured it out
      It was because I didn't make surfaces from all my sketches in the geometry.
    • Aniket
      19182560, very good! if you get some time, please elaborate issue and the resolution as a reply to your original question, and mark it as solution so that it will help if anyone has similar question in the future!
      -Aniket
    • mufid12
      guys, help me please. my ansys is 2020 R2 student version. i use asus vivobook s410 un, ram 8 gb, NVIDIA geforce MX150. windows 10, my ansys cant progress the mechanical. when my geometry done, i want to start my mechanical but my over all progress in mechanical is stuck in 0% even i wait so long for the progress but its same, the progress still stuck in 0%. n
    • Alexn
      I have exactly the same problem (windows 10).n
    • mufid12
      did your ansys work?
Viewing 5 reply threads
