Solver engine convergence error
    • tahm
      I am getting this error message. How to resolve?
      The solver engine was unable to converge on a solution for the nonlinear problem as constrained.  Please see the Troubleshooting section of the Help System for more information.
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
    • tahm
      Here are some screenshots
    • tahm
      I was doing a 2D plane strain analysis of soil element
    • peteroznewman
      Increase the Initial and Minimum Substeps to 100.
      Insert a command object
      NEQIT,50
      This will tell the solver to keep going for 50 iterations instead of doing a bisection or stopping after 26 iterations.
    • tahm
      Still I am getting the error
    • peteroznewman
      You have to improve the element shape where the solver is unable to obtain a force equilibrium and fails to converge.
      You can find out where that is by typing a 4 in the field called Newton-Raphson Residuals under the Solution Information Folder.  Take out the NEQIT command. Solve. When if fails to converge, you will have 4 plots under the Solution Information folder. The plot is the Newton-Raphson Force Residual plot. The Maximum value on this plot is where you need better elements.
      I already know that it will be in the interior corner.  If you put a small radius in that corner instead of a sharp interior corner, that will help it converge.
Viewing 6 reply threads
