July 20, 2023 at 3:22 pm
Anand V
SubscriberI am using Ansys 2023 Student version. I am unable to analyse even simple non-linear problems. Even the one from Ansys innovation courses gave this error, "The solver engine was unable to converge on a solution for the nonlinear problem as constrained. Please see the Troubleshooting section of the Help System for more information."
May I pleaseknow if this is due to the limitation of my system or is it sue to the limitation of the student version software or is it some other setting in my system?
July 20, 2023 at 5:16 pm
Sampat Kumar
Ansys EmployeeHi Anand ,
Will you please check if the large deformation is on or not?
Sampat -
July 20, 2023 at 5:53 pm
Anand V
SubscriberLarge Deformation is "on"
July 21, 2023 at 7:26 am
Nanda Veralla
Ansys EmployeeHello Anand,
Well, it might be due to limitation of student version. How many nodes/elements are we dealing with here? Does the solve.out file contain any error, which can give more insights.
Thanks,
Nanda
July 21, 2023 at 7:52 am
Anand V
SubscriberHello Nanda,
There are only 16951 nodes and 3444 elements whereas the Student license permits upto 100,000 nodes.
Yes! the solver file shows several similar errors, one of which I have copied and pasted here below.
*** ERROR *** CP = 7.438 TIME= 16:06:21
Element 2980 (type = 2, SOLID186) (and maybe other elements) has become
highly distorted. Excessive distortion of elements is usually a
symptom indicating the need for corrective action elsewhere. Try
incrementing the load more slowly (increase the number of substeps or
decrease the time step size). You may need to improve your mesh to
obtain elements with better aspect ratios. Also consider the behavior
of materials, contact pairs, and/or constraint equations. Please rule
out other root causes of this failure before attempting rezoning or
nonlinear adaptive solutions. If this message appears in the first
iteration of first substep, be sure to perform element shape checking.
*** LOAD STEP 1 SUBSTEP 1 NOT COMPLETED. CUM ITER = 3
*** BEGIN BISECTION NUMBER 1 NEW TIME INCREMENT= 0.17500E-01"REASON FOR TERMINATION. . . . . . . . . .ERROR IN ELEMENT FORMULATION
RESTART BY RE-RUNNING THE ANALYSIS
July 21, 2023 at 9:40 am
Sampat Kumar
Ansys EmployeeHi Anand,
Would you kindly increase the substeps so that the load incrementing happens more gradually? I can see from your error message that it has one substep.
Sampat -
July 24, 2023 at 6:00 am
khesh.selvaganapathi
SubscriberAnand,
what plasticity model are you using ?
bi linear or multi linear ?
are you loading by displacement or force ?
i have simulated necking with a 2D axisymmetric model with multi linear plasticity and displacement control, displace it to a reasonable level, you should be able to calculate what this is, for say 30% strain.
your high distortion elements warning is probably in the necking region.
Track reaction force and if necking has occured, you will see a peak force that then drops.
4440
2953
1427
1322
