March 19, 2022 at 6:18 am
Mak
SubscriberHi
I got some problem similar to yours
when I put my case into HPC and try to run it, it shows
_______________________________________________
Warning: property-info: unknown property: characteristic-vibrational-temperature
Error at Node 2:
Error at Node 4:
Error at Node 16:
Error at Node 8:
Unknown independent variable for polynomial
Error at Node 5:
Error at Node 15:
Error at Node 1:
I put the Whole report here
And my mesh
Can you or someone help me to fix it?
Thank you
Mak
March 21, 2022 at 11:44 am
System
SubscriberThis discussion was created from comments split from: Persistent error when trying to run Ansys-Fluent case on HPC. -
March 21, 2022 at 11:45 am
Ansys EmployeeThe warning may not be important, it may just be an older case file being run in the newer solver. However, the polynomial error may be more instructive. What models, material properties and expressions are you using?
Trending discussions
Top Contributors
2524
2066
1279
1096
459
Top Rated Tags
