Solver getting stuck at 10% in mechanical
    • TomY610
      I am uses ANSYS 2020 R1 for school. I have downloaded the application on my desktop. When trying to solve my model, the loaded gets stuck at 10%. However, when I use Amazon Appstream, the same file solves perfectly fine. Has anyone else encountered a problem like this? Or have any idea what the issue could be? Thanks!
    • ciema
      Can you attach error window?
    • TomY610
      Well here is the error window, but it just states that I aborted the process after a while because it was getting stuck and not loading further from the point shown in the first snip.
    • ciema
      Can you present model? Boundary conditions and mesh? It will be much easier to find the reason
    • Gary Stofan
      This can happen if the Distributed solver fails to start.
      Try the non-Distrbuted solver.
      In Mechanical, Home (Tab), -> Solve. Uncheck "Distributed" box.
      Let us know if the solve progresses.
    • TomY610
      It worked! Thank you Gary!
Viewing 5 reply threads
