May 12, 2020 at 12:43 pm
arkarnad1
SubscriberI tried the solution, but the problem is still occurring, what should I do?
https://discoveryforum.ansys.com/t/m2nzhw/discovery-aim-solver-is-stuck-at-100-progress
May 13, 2020 at 5:05 am
Naresh Patre
Ansys EmployeeHello Aryan
Which version are you using?
Can you share a snapshot of the Properties panel showing the appended command in the target field?
May 13, 2020 at 12:42 pm
May 14, 2020 at 1:34 pm
Naresh Patre
Thanks for the snapshot. It looks ok!
Can you try running AIM in administrative mode and see if it helps?
Which simulation are you running - fluids or structural? IF fluids, can you try reducing the number of iterations and see if that helps?
If the above suggestions don't work, I will have to look at the model for further investigation. I will send you a secure transfer link for uploading the file.
3930
2649
1861
1272
610
