Solver not starting for solution
    • krs19
      I am doing a 2d simulation of adsorption and desorption of carbon where I am using 4 UDS to store calculated values for the adsorption and desorption.
      But when I am running the simulation I am encountering the following error
      Divergence detected in AMG solver: temperature Stabilizing uds-3 to enhance linear solver robustness.
      Stabilizing uds-3 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: uds-3
      Error at host: floating point exception
      Error at Node 0: floating point exception
      ===============Message from the Cortex Process================================
      Compute processes interrupted. Processing can be resumed.
      Error: floating point exception
      Error Object: #f
      Registering Udf, ("G:Canister SimulationUDFudf.c")
      Calculation complete.
    • Karthik R
      Administrator
      What is your mesh quality? (Max Skewness and Min Orthogonal quality) Please check if you have a good mesh to start with?
      Also, are you able to compile your UDF without any errors?
      Karthik
