Solver pivot issues of elastic shell snadwiched between poroelastic solid
    • Fraser Shields
      I have a model of a biphasic/poroelastic solid reinforced with elastic shells. I have replaced solid 186 elements with CPT216 elements to model the fluid pressure and flux when the construct is under compression. However, I am getting solver pivot errors when running the model. The model has shared topolgy between the solid and shells, and runs completely fine when it has solid 186 elements consititing of a linear elastic material. However, upon changing elements, the error arises.
      Here is a link to the project:
      https://drive.google.com/file/d/1P1JmyINikenVzwqfqQGCw94MCGd9vIDi/view?usp=sharing
      It contains the following ADPL command snippet in the analysis section:
      !   Commands inserted into this file will be executed just prior to the ANSYS SOLVE command.
      !   These commands may supersede command settings set by Workbench.
      !   Active UNIT system in Workbench when this object was created:  Metric (um, kg, uN, s, V, mA)
      !   NOTE:  Any data that requires units (such as mass) is assumed to be in the consistent solver unit system.
      !                See Solving Units in the help system for more information.
      /PREP7
      ! Define an element type with the desired real constant (CPT216)
      ET, 9991, CPT216
      KEYOPT, 9991, 12, 1
      ! Select the solid elements you want to modify (SOLID186)
      ESEL, S, TYPE,, 13, 57
      ! Modify the selected elements to use the specified element type (9991)
      EMODIF, ALL, TYPE, 9991
      ESEL, NONE
      ! Define proelastic material for solid elements
      MP,EX,99999,0.001 ! YOUNG'S MODULUS
      MP,NUXY,99999,0.3 ! POISSON'S RATIO
      FPX=2e-15 ! PERMEABILITY
      ONE=1.0
      TB,PM,99999,,2,PERM
      TBDATA,1,FPX,FPX,FPX
      TB,PM,99999,,2,BIOT ! BIOT COEFFICIENT
      TBDATA,1,ONE
      ESEL, NONE
      ! Define linear elastic material for shell elements
      MP,EX,88888,0.1 ! YOUNG'S MODULUS
      MP,NUXY,88888,0.3 ! POISSON'S RATIO
      ! Select the solid elements you want to modify and assign material 1
      ESEL, S, TYPE,, 9991
      MPCHG, 99999, ALL
      ! Select the shell elements you want to modify and assign material 2
      ESEL, S, TYPE,, 1, 12
      MPCHG, 88888, ALL
      ! Select all elements
      ALLSEL
      ! Continue with the solution phase
      /SOLU
      Any help would be much appreciated.
      Thanks!
    • Ashish Kumar
      Forum Moderator
      Ansys employees cannot download the attachments. The command snippet is used to change the material. Can you share snapshots of the setup - with that, it might be easier for forum members to comment more on your post.
      Ashish Kumar
