November 18, 2020 at 5:47 pm
Yazun
SubscriberNovember 21, 2020 at 2:38 pmpeteroznewman
SubscribernThe vanes must be attached to the shaft, so you want Bonded Contact instead of frictionless contact. If the whole assembly was solid meshed, then it would solve without error.nNovember 21, 2020 at 4:20 pmYazun
SubscriberThank you for your comment I did this and it worked nViewing 2 reply threads- The topic ‘Solver Pivot warning detected in the UY degree of freedom. Help’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
