August 2, 2018 at 12:04 pm
mohamed elbanhawy
SubscriberThis errors happened when i try to solve in ansys Fluent and when i tried to open results in the workbench it gives me this message "no applicable licences available right now " >>> what should i do to solve that
August 2, 2018 at 1:09 pm
ANSYS_MMadore
Ansys EmployeeHello Mohamed,
It could be due to the path root name. e.g. if the folder name where your are working has a 'strange' character, like ?,!,",ñ,etc. try to rename your folders. It could also happen if there is not space on the drive where you're saving.
Another cause might be a faulty gzip.exe, incompatible with your Windows version or just a broken install. Go into the fluent folder and find the gzip.exe and do a simple test to see if it would work in cmd. Try to gzip a text file and see if it crashes!! If so, this tells you that the gzip.exe file itself was corrupt or not compatible with windows.
You can try updating the version from gzip.org.
Thank you,
Matt -
August 2, 2018 at 2:23 pm
mohamed elbanhawy
SubscriberThanks for replying
How can choose the right one from this site and should i have to delete the old one when i insert the new one
finally is this the reason of problems with saving the project from Fluent ?
August 2, 2018 at 7:15 pm
ANSYS_MMadore
Ansys EmployeeIs gzip.exe causing the issue? Did you test as noted?
You can try the most recent version from the site. Rename the old one to gzip.exe.old and replace with the new.
Thanks,
Matt -
August 2, 2018 at 8:15 pm
mohamed elbanhawy
Subscriberyeah i did but the problem still there
- Workbench error
- Workbench not opening
- License Error
2600
2088
1319
1108
459
