May 5, 2022 at 4:07 pm
HPC_Tinkerer
SubscriberIs there a way to solve multiple sensitivity studies that have been copied, pasted and slightly modified in parallel. I am running a sensitivity study where I would like to evaluate a system response by changing four variables in a sensitivity study. I have set each of these sensitivity studies to only include one variable at a time so the others are held constant and planned to duplicate this setup and then repeat the process three more times only including one variable at a time. The machine I am using has more than enough cores to multiple solves in parallel and access to an available license pool is not an issue. When I try to run more than one sensitivity study at a time I get the following error:
May 6, 2022 at 1:07 pmGeorge Karnos
Ansys EmployeeHPC_Tinkerer
Are you running the Free Student Version, or a commercial version?
This may not be possible in the Free Student Version.
My Suggestion, if commercial version, is to log a Service Request, as I believe you are a Channel Partner.
Viewing 1 reply thread- The topic ‘Solving Multiple Sensitivitiy Studies in Parallel’ is closed to new replies.
Trending discussions- how to build the scenario of earth-lunar communication networks
- Ansys additive
- Im getting a big Error after Installing Ansys and Opening the Workbench
- Numerical analysis of thermal cabin management of using Phase Change Material
- Ansys additive science
- nonlinear optical system
- EOIR in STK 12
- How can I work with System Coupling?
- Displacement convergence in System Coupling
8832
4658
3159
1688
1482
