March 12, 2023 at 10:36 am
Leiron Babi Mota
SubscriberDo you have any tutorial on how to obtain the power transfer efficiency of a Wireless Power Transfer System using results data from Ansys Maxwell?
Can someone help us identify the reason why our results didn’t match the results of our reference study? The values that we used for our model were equal to our reference model’s specifications.
Please see the tables below to see the results from our reference study.
Distance (mm)
Reference Model
Leakage Magnetic Field (uT)
uT of our simulation
150
265
51.57
160
320
42.93
180
245
31.77
200
190
25.30
220
150
19.52
240
120
14.36
260
90
11.89
280
75
9.79
300
60
8.03
320
50
6.87
340
35
5.79
350
25
5.14
From reference
From our simulation
Primary turns
8
8
Secondary turns
9
9
Air gap
132mm
132mm
Primary peak current
81.88cis(0)A
81.88Acis(0)
Secondary peak current
72.74cis(-90deg)A
Ltx
37.68 uH
527.18uH
Lrx
43.81 uH
3287.63uH
Mutual inductance
3.657uH to 8.979uH
231.047uH
Operating frequency
85kHz
85kHz
Links to our files:
https://drive.google.com/drive/folders/1upfp5BAApy-WcJINQg-PxOFTLXxxjSjN?usp=sharing
If there's someone who can help us, kindly reply to this post. Thank you
Data Sources:
Wireless Power Transfer for Light-Duty Plug-in/Electric Vehicles and Alignment Methodology, SAE J2954-2020, SAE International, Oct. 2020.
S. Son, S. Woo, H. Kim, J. Ahn, S. Huh, S. Lee, and S. Ahn, “Shielding sensor coil to reduce the leakage magnetic field and detect the receiver position in Wireless Power Transfer System for Electric Vehicle,” Energies, vol. 15, no. 7, pp. 1–15, 2022, doi: 10.3390/en15072493.
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1821
1236
594
