November 19, 2018 at 5:34 pm
sameerfares
SubscriberHello All,
In SpaceClaim, what makes some lines are visible and some are not? in the sketch below the top line is visible, but the bottom line "50 in" becomes visible if i click on it in the tree. this is similar to all bottom lines. i did try Always Visible, but it didn't change anything.
Sam
November 19, 2018 at 7:54 pm
SubscriberHello Sam,
When you are in 3D Mode, you can see all the visible lines.
When you select Sketch Mode, you identify a sketch plane. SpaceClaim automatically hides objects in front of the sketch plane so you can see through them to the sketch plane. Go back to 3D Mode to see all the lines.
Peter -
November 19, 2018 at 7:56 pm
sameerfares
SubscriberThank you Peter!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2534
2066
1285
1104
459
