some problem of defining prony shear relaxation parameter
    • Zhenhao Qian
      When I fitting the shear relaxation curve, I found I must define the elastic modulus, but I don't know which modulus should I define, Instantaneous modulus or equilibrium modulus?
    • John Doyle
      Assuming this is a small strain application, the base material can be defined with the instantaneous linear elastic modulus and Poisson's ratio.
      If this is a large strain application for a polymer type material, consider defining  base material as a hyperelastic strain energy density function.
      • Zhenhao Qian
        Thank you for your reply! And I’ m sorry about my late reply.
        I also have some questions
        1. Would I interpret small strain as the part before plastic stage?
        2. Before I do stress relaxation test about my material, I do uniaxial compression test to confirm its linear elastic stage. Because as far as I know, the stress relaxation test must ensure that it is within the linear elastic stage of material. Due to limitations, I can only apply load at a low speed (about 10mm/min to 60mm/min), I ‘m not sure how to confirm the linear elastic stage, because before 0.2 strain, the uniaxial curves don’ t seem to be completely ‘ linear‘ . I’ m not sure whether my understanding is correct.
          The figure shows the uniaxial compression curves. Red line = 10mm/min, Blue line = 60mm/min.
