Some walls were disappaered at Boundary Condition setting of Walls
    • DongwooChoi
      Hello, I'm trying to convection problem.
    • Swathi V. V.
      Hello You donÔÇÖt have to give separate names to the interface walls.Fluent will generate a wall and a its shadow wall (walls adjacent to the fluid/solid and solid/fluid respectively) on its own. In your case, say "wall plate fluid contact" and "wall plate fluid contact-shadow."
      I guess the mesh is conformal! For conformal mesh, the wall and corresponding shadow wall will be automatically thermally coupled and you don't need to create a mesh interface separately. Please check that the thermal condition of the wall and its shadow wall is coupled.
      Please refer to the section ÔÇ£7.4.15.5.8.Thermal Conditions for Two-Sided WallsÔÇØ in7.4.15. Wall Boundary Conditions (ansys.com)
      Regards
    • DongwooChoi
      Thank you for replying!
      That helped me a lot.
    • Swathi V. V.
      If your query is solved, you can mark the solution as answered.
    • DongwooChoi
      I see.
      I clicked Yes to "Did this answer the question?"....So is it done?
    • Swathi V. V.
      Yeah, its done. Thank you
Viewing 5 reply threads
