March 10, 2023 at 2:57 am
Zhixuan Zhang
SubscriberI have downloaded the ansys for students 2023R1 but after the installation, when I was trying to run for example the Mechanial, it says that I don't have the license. Also, when I look into the folders I truely couldn't find any file ended with ".lic", aslo have looked through the zip I've downloaded from the website, there is no license contained, also the file path seems to be very strange "ANSYSACADEMICSTUDENT_2023R1_WINX64\student\WINX64" but inside the WINX64, there is no such folder called sharing,but a folder named "licensingclient" and inside it only a file named ".acldata"
March 10, 2023 at 3:12 am
pxiong5
SubscriberI got the similar issue. But I'm using a floating license, and it doesn't work for R2023 and only works for the older versions.
March 10, 2023 at 9:40 am
Ansys EmployeeStudent doesn't have a normal licence, and isn't expected to link into any Campus systems. The "normal" software needs a licence manager to connect to the Uni server(s).
The software is also paired to the licence manager, so generally an older solver install will work with the latest licence manager, but new software may not work with the older manager.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
3744
2573
1817
1236
594
