December 2, 2022 at 1:14 pm
jannatul nayem
Subscriberhow i will incident p polarized light in a waveguide to get SPR.How i will get sensitivity and detection limit
December 9, 2022 at 10:50 pm
Kyle
Ansys EmployeeHello,
You can use a mode source to inject light into the SPP mode in a plasmonic waveguide: https://optics.ansys.com/hc/en-us/articles/360034902153
You can check the electric field components of the mode to see the polarization. I'm not sure what you mean by sensitivity and detection limit, how to calculate them will probably depend on the device design. These biosensor examples might be helpful for you:
https://optics.ansys.com/hc/en-us/articles/360042322634https://optics.ansys.com/hc/en-us/articles/360042833173
https://optics.ansys.com/hc/en-us/articles/360042089353
- Error on Lumerical device
2656
2120
1345
1118
461
