May 18, 2023 at 11:27 am
Uzma Yaqoob
SubscriberHello Everyone
Is there any way to use three different wavelengths that are randomly apart from each other for a single source?As generally for broad band excitation what we do we provide a range of wavelengths then make them linearly apart from each other to see responces on sliced wavelengths.But what if i want to excite the device with 430nm,467,and 480nm?as if i select a span then set frequency points that are apart by 1nmthen it would be really time consuming as the solver would do siimulation for the entire range.Plz guide in this regard. -
May 18, 2023 at 4:28 pm
Guilin Sun
Ansys EmployeeIt is absolutely not necessary for linear optics to use discrete wavelength. You can set a broadband source, but set the monitor to only record those 3 or any number of specified wavelengths.
If it is nonlinear , then you may need to add 3 different sources centered at the desired wavelengths. Please refer to this example to get quasi-monochromatic source: https://optics.ansys.com/hc/en-us/articles/360041722614-4-level-2-electron-material-model
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5162
3251
2443
