December 12, 2020 at 11:00 pm
DJENDARA
SubscriberHI , I HAVE A GREAT PROBLEM WHEN I HOOK AN SOURCE TERM I HAVE FOUND THE DIFFERENT RESULTS SPECIALLY WHEN I RUN TOW CALCULATION HAVE SAME STRICTURE EXP : POISSON EQUATION USING "UDS" VS HEAT EQUATION USING ENERGY EQUATION IN FLUENT USING SIMPLE ALGORITHM I FOUND THE FOLLOWING RESULTS :
1 /WHEN I RUN EQUATION WITH INTERPRETED SOURCE TERM FOR ENERGY GIVE REASONABLE RESULT
2 /WHEN I RUN EQUATION WITH INTERPRETED SOURCE TERM FOR ENERGY GIVE HUGE VALUES
THE UDF ARE :
DEFINE_SOURCE(ENERGY_SOURCE, c, thread, dS, eqn)
Domain *d = Get_Domain(1);
int fluid_ID = **;
Thread *t_fluid = Lookup_Thread (d,fluid_ID);
Source = C_T(c,t_fluid);
dS[eqn]=1;
return Source;
DEFINE_SOURCE(POISSON_SOURCE, c, thread, dS, eqn)
int fluid_ID = **;
Source = C_UDSI(c,t_fluid,0);
dS[eqn]=1;
return Source;
PLEASE HELP !
December 14, 2020 at 11:59 amRob
Forum ModeratorAre you adding the source to the energy equation?
Viewing 1 reply thread- The topic ‘SOURCE TERM IN FLUENT !’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
