September 11, 2022 at 7:32 am
afshiin.a
SubscriberHello.I have a question about defining wavelength in the source. When we applied wavelength start and stop values equal to 260 nm and 2000 nm, we saw that the spectrum vs. wavelength curve is asymmetric and is shown as a stretched form (picture 1). While considering wavelength start and stop values equal to 1500 nm and 1600 nm (picture 2), the spectrum vs. wavelength curve is approximately symmetric.I want to know what phenomenon changes the spectrum vs. wavelength curve behavior by changing wavelength start and stop.
Thank you -
September 12, 2022 at 5:39 pm
Guilin Sun
Ansys EmployeeBy default, the source spectrum vs frequency uses Gaussian shape, so for large bandwidth the spectrum vs wavelength is not a gaussian, due to the inverse relationship between wavelength and frequency.
When the bandwidth is small, the an-symmetry is not that obvious.
A side note: the spectrum shape is not important in linear simulation, since thefrequency-domain results are alwasy normalized witht the source spectrum, which removes the shape of the source spectrum. Please refer
https://optics.ansys.com/hc/en-us/articles/360034394234-Understanding-frequency-domain-CW-normalization
I hope this helps.
- Error on Lumerical device
2656
2120
1347
1118
461
