March 27, 2023 at 8:31 pm
satri
SubscriberI have 2 questions
1) Is it possible to create trapezoidal cylinders in space claim at an arbitrary location and oblique height.
What I mean by that is, the center of my first circle (base circle) is in XY plane and the second circle is in YZ plane the height of the cylinder is the distance between the centers of the two circles in XY and YZ plane.
2) Is there a python script command to create a cylinder in space claim?
March 30, 2023 at 1:40 pm
Naresh Patre
Ansys EmployeeHello @satri
1) You can try using the Blend tool to create a solid from the 2 circles that you mentioned. Check out the below video on Blend tool:
How To Use the Blend Tool - Lesson 4 - ANSYS Innovation Courses
2) You can use the Record feature from scripting editor to record the script command of "Cylinder" tool.
- Naresh
3275
2447
