space claim options
    • m.caragiuli
      I've noticed that when using Space Claim the properties of a command are not available. For instance, if I select holes I do not have any properties regarding cap or patch, together or separately. Is there a missing option or add-in tool?
      Thank you
    • peteroznewman
      Please insert an image showing what geometry you are looking at and say what you want to do.
    • m.caragiuli
      In the Space Claim R12020 I need to close the holes and if I select the holes tools I know from the guide that there should be some properties such as cap or patch as in the picture
      holes option
      , but the properties window in the bottom left corner is empty. I don't know why.
      holes
