September 2, 2022 at 10:06 am
tumulpurwar
SubscriberHello All
i have imported sketch from autocad as dwg, as can be seen in photos, you can see in zoomed photo,there are many closed figures, in the dwg which i imported.
i expect that spaceclaim should created automatic surface for such closed curves.
but why after importing,it is not making surface for closed curves by itself??
September 2, 2022 at 12:35 pm
SubscriberIn SpaceClaim, you can check the box for Layout Sketch. That will prevent closed loops from automatically changing into surfaces.
You can select a closed loop then click the Fill button on the Design tab to create the surface manually.
September 5, 2022 at 5:21 am
tumulpurwar
SubscriberHi Thanks Peter
See steps below
1)I imported sketch
2) I click on plane associated with given sketch and go on sketch mode
3)if un tick or tick "CREATE LAYOUT CURVES"...it bringing no automatic surfaces for closed sketches.
i dont want use patch tool, as i have such sketches almost 100, it will consume crazy time.
now can you telll what still i am missing.
what you said it works if i a make such closed sketches inside spaceclaim, as the sketches in photos above are imported from Autocad,it doesnot create automatic surfaces for closed curves.
I dont undesrtand why
September 5, 2022 at 7:39 am
tumulpurwar
Subscriberok ,it works, i mean it is creating automatic surfaces over closed sketches.but it only create when i move the input sketch some distance and than delete its associativity with its associated plane(in simple word, i delete taht plane)
Other problem is its filling automatic surfaces after following this MOVE command step,but its creating all filled closed curves as one single surface.
i want them to remain seperate, what shall i do???...i need them ssperate surfaces as i want provide thickness to them seperately as all have different thickeness
September 5, 2022 at 7:40 am
tumulpurwar
Subscriberok i found, need use DETACH command,than it create seperate surface..cool..thanks Peter
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
