January 30, 2023 at 11:24 pm
CH Lee
Subscriberhello, as title the application just instantly shut off when i try to launch it then nothing else happen after, spaceclaim 2022 r2 , already try with run as administrator and reinstallation , please help
January 31, 2023 at 1:27 am
Atharv Joshi
Forum ModeratorHello CH Lee ,
Can you please try activating the licenses using the command window and then try launching the application?
Please refer Discovery Subscription license - Command line options for instructions on activating licenses through command line.
Let me know if this resolves the issue for you.
Thanks and Regards
January 31, 2023 at 3:26 am
GUICAD
SubscriberHello,
This issue appears with all of our customers.
Are you looking at the problem or will the solution always be to go through a command line ?
Thanks,
January 31, 2023 at 5:37 am
Atharv Joshi
Can you please share the log files located at ~
/Ansys Inc . Install.log
Install_licconfig.log
Install.err (if it exists)
January 31, 2023 at 10:18 pm
CH Lee
SubscriberAtharv Joshi hello sorry for the late reply ,i would like to thank you for the speedy reply ,the following solution provided using the command line help solve the problem, thank you very much, i have attached the following files and some extra few as requested hope these help. Thanks again!
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8700
4658
3151
1672
1446
